Tranny removal
Started by Jthomas, February 17, 2012, 02:43:06 AM
Quote from: marshall on February 17, 2012, 07:27:48 PM
unbolt the convertor from the flywheel, take the transfercase off the trans. there is no shortcuts to this job.  if your outside have a can for every nut and bolt, and take the distributor cap off so you dont break it.
Idk how I'd break the distributer cap?
Quote from: Jthomas on February 17, 2012, 07:40:42 PM
If you dont support the back of the motor, when you pull the trans back the motor  will drop and your dist will hit the firewall.  Crack goes your cap.
Ohhh. Thanks, GREAT tip.
But could I get this rebuilt into a proformance trans? And at about how much $$ ?
the harvester
yes you can but it will cost big bucks and if you really plan on running that kind of power i would look at a different trans
Quote from: the harvester on February 17, 2012, 09:19:38 PM
Yea, I already got the power. But I REALLY like the 700 cuz of 4th gear. I drive this truck daily in the summer time, and after work and on weekends I bog/race the living p00 out of it. So I do use the power I make.
And I like 4th gear for roads, I'm not spinning high rpms and save a lot on gas.
x2 if you really have 850 hp I would look for a 400th to have built to run the power also with that kinda power your gunna want a converter built to run your motor , gear, tire size, and truck weight so everything works right.
Quote from: betterbeaters on February 17, 2012, 09:51:31 PM
Yes I've been doing my hw on what I can. It's  not 850hp, it's 800 (depending on psi) I just want to be safe. But I need a 10" 3500-3800 stall, and one that's for nitrous/blower applications. I do have a tranny cooler, but idk how much that will help. And I know a th400 would be the best for what I got, and it's alot cheaper. But I don't like high rpms on the road. But I guess that means drive slower or get bigger tires ;)
Will I run into any trouble swapping the 700 for the 400? Like any mounting differences? Or length changes I have to worry about?
Quote from: Jthomas on February 17, 2012, 10:30:06 PM
shouldnt maybe have to mess with shifter linkage for tcase?? but make sure u get the acutal mount for trans
Quote from: OHEARN.2012 on February 17, 2012, 10:58:17 PM
I figured the linkage. But what trans mount?
Quote from: Jthomas on February 17, 2012, 11:08:01 PM
the mount that goes across from frame rail-rail that holds up the back of your trans/transfer case. or if u want u could build your own
ice87
What are you running that has 800hp on the street. If you really have that much power I don't see overdrive helping that much since it drinks the gas anyways. I would go for Turbo 350 or 400 over a 700r4 anyday with that much power. You could always go 4l80e if you really want overdrive but that's alot of money.
Quote from: ice87 on February 17, 2012, 11:14:31 PM
4l80e wouldnt be the best lol that would be alot of money you would have to get a stand alone computer
ice87
For overdrive built transmissions they can't be beat. Alot of money but the newer 1000hp vettes are swapping from the pro built 4l60es to the 80s because they can handle anything you throw at them.
Quote from: ice87 on February 17, 2012, 11:22:46 PM
yea but you will probably have more into having it built then its worth 800 hp seems a little much for the road imo
Well, have this old built muscle 427 sitting in the polbarn. As is it's about 6-700hp. Got a blower now, putting a few pounds. Got bored this winter, looked at the truck, looked at the motor, looked back at the truck, then smiled. I think some of you guys may have had that feeling befor.
But as far as the trans, I blew my $$ fast on the motor. Lol
So budget wise, I'm leaning towards the 400, but since I'm out of $ and short on time.I figured I would just bite the bullet and was just going to try and keep the 700 and just save up and build it since I already have it. Cuz I'm worried I won't find a th400 in time.
Quote from: OHEARN.2012 on February 17, 2012, 11:26:10 PM
When the trucks finished I'm selling it and putting the motor back into a car.
ice87
What the compression on the motor without the blower
I have about 950 bux into my 700r4, and 250bux of that was labor.
