Tranny removal
Started by Jthomas, February 17, 2012, 02:43:06 AM
Can I drop the trans and the Tcase at the same time? Like leave the Tcase still attached to the trans.
Jr
yes but double the weight if u re not using anything ...
yea depends alot on what it is in and it does help with weight ALOT they are heavy as hell
It's a 700r4 with a 208 Tcase. I was gunna drain all the fluid so I'm not holding an extra 14qts. But it will be me and a friend removing. Don't have a tranny jack:( and it's cold outside
4x4ZR2
i would just split em its like 6 bolts holding them together
==nw chevv ==wn
Quote from: 4x4ZR2 on February 17, 2012, 01:08:29 PM
Well I know there's a support bar that goes from the Tcase to the bell housing. It's cold outside, I don't want to be messing around too long. Lol.
 still will be a bictch for 2 person cuz u wont be able get in good position to hold it up , but good luck and be safe    , use jack or maybe straps to hold em up while u re unbolting em
Quote from: Captn. J on February 17, 2012, 02:37:51 PM
Straps are a good idea! Thanks. I don't have a jack, but the truck is tall enough that I can kneel comfortably, so I could prolly hold the top or bottom of the trans on my shoulder while my friend holds up the other end.
I always drop the tcase b4 I drop the trans.  It only takes like 15 xtra min with a 208
How much tranny fluid does that tcase hold?
Blake Scheuneman
it doesnt hold that many quarts maybe 4 or 5
chevv ==dew alll
Should I leave the T converter on the flywheel? Or on the trans shaft?
First trans removal, can't ya tell?  ==noob
Quote from: Jthomas on February 17, 2012, 03:34:42 PM
thats easy to do to just pull it.
Blake Scheuneman
i would leave it in the trans
chevv ==dew alll
Can my trans be built up to handle around 850hp?
unbolt the convertor from the flywheel, take the transfercase off the trans. there is no shortcuts to this job.  if your outside have a can for every nut and bolt, and take the distributor cap off so you dont break it.
