project low 'n slow loll updated pg2
Started by Mudbuster, March 20, 2012, 12:54:56 AM
well at the parma the end of last year I broke the front leaf springs in the jeep so I started collecting parts. Here's some of the plans there are a few that I may do if money permit's that only a few people will know about.
1. 4 link front and rear
2. coil overs or air shocks (haven't decided for sure yet)
3. full fiberglass body
4. full roll cage not going to reuse any of the factory cage.
For those that don't know my Jeep it's a 95 wrangler, with fullsize chevy axles, 4:56's detroit rear, 4 wheel disk brakes pretty healthy 383, 350 manual valvebody, 3200 rpm 8" edge converter, 205, and usually 42" tsl's MSD 6al and probillet, b&m megashifter, custom airbox motor/tranny mounts, rci fuel cell, holley electric fuel pump, redtop optima,
I built this thing from a stock 4 banger with some help when i needed an extra hand or two.
here's a few old pics
this is the only pic I have of the tub before I started it's plastic surgery
here's some of how it looks right now
Newbie
looks rad bro! keep up the great work!
got a bunch of stuff of in prep of the removal of the stock tub. Hopefully by the time I come in for the night tomorrow night the tub will be ready to come off. All that's left for that too happen is some wire's body mounts, and fenders. I'd have worked on it more but my little 3/8's cordless impact aint doing the job and I twisted both my t40 and t50 bit's so I'm gonna bring home my snapon bits and 1/2" titanium from work if that don't work I guess I'll fire up the plasma cutter ;)
355REDNECK
WHEN IN DOUBT THROTTLE OUT
solid 12
looks good bud I can wait to come check it out when I get back
85cHeavyMetalBogger
more progress tonight now I get to take a break till I can get a few guys over here to help take the tup off ==roxx
this is what the jeep looked like just a couple of day's ago when I DROVE it into the garage
now here's what it looks like ==doh
here's just some of the parts that I've collected for this project
DOM
missalignment spacers
hiem joint's thanks to Wildtime fab
BOGIN4D9
muddnoob
tubs off the frame and started cutting brackets off. In the morning I'm gonna go buy a couple dozen lol grinding disks and some cutoff wheels and go to town, every bracket except motor and tranny mounts are coming off same goes for the axles.
I'll get some pics in the morning it's dark and raining right now.
Ok here's some current pics the only bracket's that need to be cut off are the spring mounts. Other wise I just need to grind everything down and repair a couple spots in the frame then the build can really start
I even went and got my new dash today it's going to be the smaller of the two I cut it from one sheet
here you can see where the axle centerline is and how far I plan on moving it not much but enough
Squirell
