BLOOD THIRSTY
Started by Merc09, March 07, 2013, 12:44:19 PM
mud gremlin
Go big or go home
Merc09
NEW SWITCH PANEL THANKS BC775
Merc09
Getting stuff wired up. About to adjust valves. Hopefully shell be running by the weekend
fordrunner
That's a sweet switch panel mine just has light switches lol
Merc09
Well couldnt sleep last night so i started on the truck again. I got the belt tensioner repositioned, the valves adjusted, and set the timing. Along with some other small stuff. Still need an alt, a serpentine belt, a floor shifter and cable, and trans fluid. Gotta have this thing done by the 15th
You can still run/time it, then re-lash valves on just the battery. I haven't had an alt in the truck all year.
Merc09
Quote from: Jthomas on September 25, 2013, 06:31:37 PM
I know im gunna still put an alt on it. Its not gunna stop me from running it if that ends up being all i need.
Merc09
#207
Well i got all but the starter and alt wired up. Gunna put the rad in run hoses and put the torque converter bolts in next.
yukonjake
BC775
get that thing going will ya lol.
Merc09
Quote from: BC775 on September 26, 2013, 03:59:32 AM
Im workin on it! Lol. I dont have the resources that some of these other people got on here. Lol
BC775
Quote from: Merc09 on September 26, 2013, 12:16:10 PM
What you mean you other people?
Merc09
Quote from: BC775 on September 26, 2013, 04:04:32 PM
Lmao. You should let me bring it by your shop we can knock it out real fast. Lol
Merc09
Merc09
The radiator is sitting in its place it just needs to be bolted in and the carb is now sealed and bolted to the intake now. Gotta hook up fuel lines and wire the starter. Run trans lines and get fluids in it along with the serpentine belt and itll be ready to fire.
Merc09
I gotta carb spacer from diversified today.
Merc09
Got the rad mounted my buddy gave me an electric fan and a cap for the back so i got those mounted and the fan wired up. I went and got both fenders this morning so now the truck has all the sheet metal back on now. Just a little bit more to go and itll be done... For now lol.
Merc09
Heres some picturessss
