Pulled the trigger on a new project, wife say's it was my foot
Started by jimmy101, July 11, 2014, 01:08:40 AM
just one more
jimmy101
Thanks guy's. I'll post more pics when i'm a little further down the line.
jimmy101
I got the bearings repacked and all the new seals into the front axle. I flipped the hubs for a narrower stance and swapped the knuckles from left to right so as to put the tie rod in front of the axle.
jimmy101
I made a beefier mount out of the old one.  I increased the tube to a 2" diameter and increased the bushing from 1" to 1 1/2" diameter. I also in creased the bolt from 7/16 to a 9/16" .   I moved the mount forward to get a better shackle angle.
jimmy101
I needed to hold my t-case in position so I could pull some measurements. Being that I only have two arms, I thought it might be a little bit cumbersome trying to pull the tape with one hand, while holdind the t-case with the other arm. So I came up with something a little lighter. ;D
jimmy101
Started to make the cradle. I still need to weld in the webbing and some cross bars.
jimmy101
Had a setback. ==pissed     By flipping the hubs, I did not take into consideration the wheel diameter (16.1), or the back spacing. After grinding away some of the rod end, letting a few curse words fly,three pots of coffee, and desperately wanting to start smoking again, I come to the conclusion that I may be able to install a 1/2" wheel spacer.
jimmy101
I did manage to get all four wheels on.  8)  It is now officially a roller.   :) ++peace
84silverado
jimmy101
jimmy101
Thanks J.C.    I refer to them as my training wheels . lol   Cause I'm quite sure they are going to teach me alot. loll
jimmy101
 8)Just got this unexpected package in the mail today.  That's a hell of a thank you!  They did not have to do that.   Thank you Memphis Equipment of Tenn.
treefarmer
jimmy101
I managed to get some more things done on the rig.  I made up some bushings and bars for the front axle and got them installed over the weekend.
jimmy101
Bottom bars are angled in straight.  The top bars  run parallel  with the leaf and then turn inward after shackle extension.
jimmy101
Please excuse my ugly mug, but this was all I could do for size description.
Air Force Fireman
Nice lookin truck man! Great build. Keep up the good work.  a=f
God Bless America!  a=f a=f
