hit and run.
Started by Dano, February 24, 2009, 06:36:27 PM
Gearz
Looks like your making great progress.   applaudd
DirtyChevy
FRIENDS: will talk p00 to the person who talks p00 about you.
REDNECKS: Will knock them the f#$% out
chevv ==rocks chevv     REAL men wear bowties
Brook Chadwell is MY baby
Dano
i hung the doors and put the box on today. now that the doors are on i see i have a piece of p00 cab. not sure if i'm gonna use it or not. its been rolled and some one put a roof skin on it. found a lot of bondo on the back side of the cab right under the window on each side. if i can find another cab quick enough i will change it out.
sucks the cab is messed up!! but keep up the good work!!
Dano
well if everything goes well i have another cab coming. with any luck i might have it home by next weekend.
Gearz
That's cool you found another one. I think I seen the one your taking about. It looked real nice in pic. Hope it works out.
Dano
Dano
didnt get anything done to the mudtruck this weekend but, i got the new trans put in the 1ton. i put a body lift on it and was putting a 4" suspension lift on it too but found out the lift i was getting was for a 1/2 ton, so i guess i will have to live with just the body lift for now. next i need to get a leveling kit for it, and a little bit bigger tire, i think it looks like a dam rollerskate.
mudslayer2008
it looks good rom where I'm sitting.    good luck on your mudder It looks like your making progress
on it.
Dano
Quote from: mudslayer2008 on March 16, 2009, 12:02:48 PM
on it.
thanxs, work on the mudder has slowed a little but its getting there. want to have it done by april 19th. there is a comp bog in butler indiana i would like to try it out at.
Dano
got some parts today that i need to put air cleaner inside the cab. a friend had this stuff on a shelf and wasnt going to use it.
STEUERDUKES
Bad A$$, Looks like your building some sweet  p00   Keep up the good work
DRIVE FAST & TAKE CHANCES!
kEEP THE RUBBER SIDE DOWN!
Dano
Quote from: STEUERDUKES on March 21, 2009, 07:41:08 AM
thanks, i really appreciate it.
Gearz
Dano
got some more goodys on the way. these should be here on tuesday. ;D
Gearz
I like the seats. I need some like that for my samurai.
Dano
Quote from: slymer on March 22, 2009, 02:53:14 PM
got em on ebay, $215.00 to my door.
Dano
well i finished taking the body off today.  and got some of the frame cleaned and painted. also installed the 6al box and coil installed under the console. once i get the new cab home it should be straight down hill to the finish. GotMud?
