project RECOVERY ONE
the beggining
looks like a baja truck!!!
END OF DAY 1 all the ifs taken off the truck!
rails all clean
its empty under there....
pitman arm on
got a lil sidetracked with the next project...
main beam on, front leaf bolts on
rear shackles on. after half a day of beating on the exhaust to get the damn pass side bracket to fit.... can ya tell?
END OF DAY 2!!!!!!!!!!!!!!!!!!!!!!!! 7 INCHES!!
camok10
84 c10 project
82 c10 beater diesel
Good job so far, cant wait to see it all done...on a side note for cleaning up your wheels use baking soda in the blaster!
homemade crossover steering bar
the leaf packs we put in. makes 6 inches of lift and 3/4 ton leaf strength! and they still flex when ya jump on the back
finally standing on its own! got a set of 1 inch lift blocks still so im gonna throw them on in the morning and adjust the rear brake bracket position and the rear should be good to go other than gear ratio needs to be changed
camok10
84 c10 project
Quote from: camok10 on May 31, 2010, 02:31:36 AM
Quote from: Kyle on May 31, 2010, 12:21:01 AM
Quote from: camok10 on May 30, 2010, 01:40:18 PM
Quote from: TBigLug on May 30, 2010, 10:11:53 AM
==cl Lookin' good!
x2
you going to remove the uca bracket's?
uca brackets?
the upper contol arm bracket's
no i need them for my custom fabbed shock mount brackets. i coulda cut em off and used the old shock bracket to a tab the previous owner had on the axle and ran a single shock setup but id rather run duals which means i need em for bracket mounting. i dont mind seeing em on there anyways
needed a 1in block to level it out. came with the rear u-bolts so i wasnt out anything  ;D call it lucky guess
