90 GMC 2WD > 4WD conversion Ext Cab Short Bed
Started by old school truck dude, May 25, 2010, 02:16:38 AM
I need to take a moment to thank all the great  GotMud? people that contributed to this build. It's been a long damn haul with alot of obstacles to overcome, but it's on the road finally, and I couldn't have done it without you guys!!  ==thanks ==thanks ==thanks ==thanks ==wgm
O man. Time to find all the bugs you missed now. Hope you didn't have too many bolts left over. loll
Quote from: Chevy Racer on August 19, 2012, 02:03:41 PM
I have buckets full of stuff that I have absolutely no idea what it goes to ==roll
Trans acted strange last night, didnt wanna shift for about 5-10 minutes unless revved way up, then just worked perfect. Im thinkin the detent cable was stickin a little bit.
So it always helps to make sure everything is full. Here is this thing doin what it does best, keepin the guys there in a job!! I guess it needs a name now, any suggestions? Also, it will need the bodywork done and painted soon. Should I go dark blue or black? ;D
After a whole bunch of horsin around lookin for metric taps and beatin hell out of the driveshaft to get it to slide again, I got the 4wd workin on this thing here finally. I just put the front axle on a toggle switch.. It works and it appears the front and rear are the same gear ratio yeahh so now I need a set of shocks and cut a hole in the floor to mount the tcase shifter, find a nice rubber boot to go over it. ==dj gmcc
 applaudd applaudd  theres some shocks over here if they will work ya can have em  ==np
Quote from: BigFrank on October 07, 2012, 12:24:26 PM
I dont know what the shocks that go on there are supposed to look like, it has no shocks at all on it loll Do you know what yours came off of?
Shifter installation
Welded it in, had to replace the bushings on the linkage - the machine I used was not a very good one loll
looks like its welded to me.  put the mat or carpet in can't see it.
Quote from: 4x4xdodgeman on February 03, 2013, 09:04:53 PM
Yup, carpet is back in it, havent took a pic of it yet, no boot to go on it..
Update, the 32s are much better tires - thanks Chris, it got attacked by a racoon and it ate a hole in the hood insulation  ;D
Might have to turn this into a daily driver for a bit - my S10 needs an ignition module  ==rant
Anybody know where to get cab corners and rocker panels cheap? If I dont do them pretty soon I wont have a cab left!  ==censor
Quote from: Eroq on April 12, 2012, 03:09:37 AM
cut the tops off them bumpstops in the pic you showed... rides a hell of a lot better when torsions are cranked up!
Soon as I get some gas in my torch bottles - movin forward with this project again
