90 GMC 2WD > 4WD conversion Ext Cab Short Bed
Started by old school truck dude, May 25, 2010, 02:16:38 AM
Ive been out here tinkerin on this thing, its amazing how much there is left to do ==roll
I finally got some $$ and got brake lines and fuel lines to put on it now, got the little fitting to go on the intake cuz I really dont care for that long curved pipe stuck in a piece of plastic, thats dumb, dont know or care why they made it like that but its fixed.. its fightin me all the way, right rear is locked up again so gotta get in there at the adjuster to get the drum off   ;D ==np
Well, I got it to fire off on ether but the fuel pump dont wanna work so gonna have to drop the tank and have a look, it does have juice to it but pump dont come on ==hmmm
if its an electic pump in the tank my step dad showed me a trick to hit the tank with something and have some one turn the key it worked for us many times
Quote from: BUDGETBOGGER03 on March 28, 2012, 11:22:22 PM
==hmmm Its been settin up for awhile, that might just do the trick - Ill try it today ;D
Quote from: old school truck dude on March 29, 2012, 11:25:07 AM
did it work?
Will try it tomorrow, had to do a buncha other stuff today ;D
if ya end up needing a pump i got 2 used ones here  ones from a s10 the other is from a full size 94
Quote from: BigFrank on March 31, 2012, 12:16:44 AM
Thanks, I still got 1 extra whole sendin unit and all from the 91, the tank leaked so I just saved the unit out of it, wrapped it up in plastic but who knows if its any good either ==roll
RUNS GOOD. Found a ground wire that wasnt hooked up. Lots more to do ;D yeahh ==rocks ==roxs ==roxx woho
Bout got the motor buttoned up except I cant find the stupid fitting I just bought to replace the one on the back passenger side of the intake for the heater, Ive looked everywhere except for where it actually is, hope I didnt accidentally scrap it!! loll
Apparently I will need to extend the wires for the speed sensor to reach the tcase, I have no idea if it will even read correctly or not.. Anybody know one way or the other ???
Quote from: old school truck dude on April 04, 2012, 12:20:40 PM
it should read correctly, I believe its and on/off sensor not a resistance reading.
It runs on a reluctor ring... dont extend any farther than you absolutly have to and keep the connections as clean and sealed as you can, maybe even use them connecters with the shrink wrap on them.  Should work fine as long as you dont add to much to the circuit.
I figure to add about 1-1.5' to it, will that cause a problem?
should be ok... just use the same size wire. It is a on/off switch in a way I suppose. Just dont want to add too many ohms since its a 5v system running off the computer.
Ok, I see what youre sayin, Ill keep it pretty short then  - thanks! ;D
Well it showed me just how important the ground wires are. It absolutely would not start until I cleaned up the engine to frame ground wire.. Would not pump fuel except for when it felt like like it which was the other day, not today loll Ran some brake lines and some other minor stuff, gettin closer ;D
Burned some rubber comin outta the shop under its own power woho
The lawn mower got ran over somehow, pics of the carnage comin soon loll
The right rear is draggin, gonna have to see whats wrong in there ==dunno Still a bunch of tweekin before its road and trail worthy ;D
Lotta space to crank up the torsion bars, looks like  ;D
