Big 2500 with Planets
Started by KHP8ntballer, September 11, 2010, 08:55:57 PM
scottsdale
KHP8ntballer
Finally got the seats in.
KHP8ntballer
Got the new Rice and Canes thanks to TOMAC!  Now I got plenty of work to do.
KHP8ntballer
Yea 1 or 2 will need tubes but they will work.
blazentrout
If you need a hand, let me know. also put the centers in BEFORE you put tubes in lol
TOMAC
KHP8ntballer
The price was unbeatable if I can make them work.  Thanks again TOMAC.  Now to install the bigger springs.
TOMAC
KHP8ntballer
The springs I have for the rear will take care of that back but all the brackets will need to be moved.  The front I may just but a beam under the front crossmember unless I can find some more springs.  Atleast that way i'll get a bit better pinion angle out of the front axle.
shortiron
I dont think the 25'' springs would have been enough. You could rise your spring perches for lift,or more body lift too.How tall are those tires,62''s?
KHP8ntballer
yea i believe there 62"s.  As for the bodylift, dont really want to see more of the stock frame so its either drop the front crossmember or like you said, put a bigger chunk under the perches.  Dont like either way but without bigger front springs i'm kinda short on the choices.
shortiron
I'll keep my eyes out for big springs for ya,you should check on chucks trucks
KHP8ntballer
So the back is set with the new springs and im finishing up the wheel centers but the front poses a problem due to the need for bigger springs.  I figure since later on I plan on changing to 4 link, i'm just gonna set the front up that way now.  Im gonna get some 2 inch square tubing for the subframe to cradle to np205 and build the tabs off of and BigShocks will be getting a call soon.
Gearz
Nice Truck !!!! Great build  applaudd
thems are some cute tires!  whats the size on the sidewall?  they look like a 30 somethin!
