Big 2500 with Planets
Started by KHP8ntballer, September 11, 2010, 08:55:57 PM
boggers55
3+3
Quote from: Eroq on February 07, 2011, 05:34:01 AM
thems are some cute tires!  whats the size on the sidewall?  they look like a 30 somethin!
They look like 23.1 x 26 or 62" tall and 23" wide. Sweet build
KHP8ntballer
Yea i think they are 23.1 x 26 or 62" tall and 23" wide.  Dont quite remember.  But the new update is I found a crack in the lifter gallery on the block so that blocks coming out and I'm getting a new bottom end all fresh this week.  Still an olds 455.  Also I decided it would be better to just get the truck running then switch what I want so I saved a ton of money for now and bought some huge leafs for the front.  Like 24" lift or something.  Ride quality will suck compare to the 4 link but its saving me around $1400 on the front for now.
KHP8ntballer
Aslo got a new tow rig/dd  7.3 Powerstroke that I put an Edge evolution race programmer on.  8 inch spring lift with 37s.
solid 12
Damn!! That is bad azz!!  Would like to see it in action!
blazentrout
looking good. give me a call some time, i got a bender and i have some input for you for a drop box.
KHP8ntballer
Well I did pick up a divorce 205 for now.   Like I said I just want to get it movin and then start putting the good parts on it.  I got a 400 trans also thats got a fresh build but idk how long that will hold either.  I figure since i got most of it already I might as well run the parts till they brake then upgrade.
shortiron
That thing looks taller than mine now.Hope you get some good use out of them axles  ;D
bbr528
are those the springs you bought from a kid at grand valley?
KHP8ntballer
bbr528
yeah thats me  hope there working out for ya truck looks good
78man
awsome profect and lookin good
Jakes Brush Removal
WOW, That is big  ==censor truck !!!!
scottsdale
that truck is huge looks good to
wayne w
KHP8ntballer
#56
Well been doin some more work.  Tires are tubed.  Got the frame completely boxed in with 1/4 inch plate.  Sub frame is complete.  Tcase is mounted.  Tranny is mounted. Mock up motor is in place.  Picked up a fuel cell.  Got the radiator mounted in the bed and a cowl on the hood in place.  Working on the hydraulic steering with a company to get the right pump setup for the cylinder. Need to order up the 1.25 heims for the traction bars.  The custom brake setup off the tcase is also coming together. Also the owner of Build it 4X4 stopped by the other day and would like it over at his shop in Marne. They want it to sit out front which is along the highway for advertisement.  Also in the deal for me is being able to work on it there which is a bit more accommodating then my driveway.   In the mean time a slightly used 350 crate motor will be installed soon just to get it moving till i finish the head work on the big block Olds.  Would like it mobile for the 4th of July.  May be a far cry but Im gonna push for it.
KHP8ntballer
#57
KHP8ntballer
