Radiator in back?
Started by Boggen Joe, January 17, 2012, 11:39:19 PM
Boggen Joe
Is it really worth putting the radiator in the rear of a bogger? I've seen a lot of TGW trucks both ways, some say it helped n some don't. So I'm trying to decide if I should put my new howe rad in the back of my k5 or not!
Looking for info from y'all thanks
it stays safer and cleaner in the back. it also can help cooling by moving it away from the motors heat..  mines in the back and it works good. and I would do it in every mud truck I have from now on!
Squirell
Quote from: betterbeaters on January 18, 2012, 12:01:03 AM
also adds a couple gallons of coolant
How can you say its safer?  its not a truck with the back of the cab.  its a blazer. radiator is in the same place as you. and it is coverd not open to the air.
Quote from: 4x4xdodgeman on January 18, 2012, 12:20:37 AM
I ment safer for the radiator..  I ran my mine in my old cj5 right behind my head.. if I did it again I would use lexan to shield it..
OLD SCHOOL
I would rather have hot coolant spray under the hood not on me or someone in the vehicle
Quote from: BlackBetty on January 18, 2012, 12:26:55 AM
you can build a shield for it mines covered better in the box then it would be in the front!
OLD SCHOOL
he was asking about mounting inside a K5 which is an inclosed area, not much air moves thru the passanger compartment which will make it overheat , and if it boils over where is it going? all over the occupants,
Red97
how well are you guys keeping cool? trying to decide if i want the radiator in the back of my pick up with a 454. I dont know if i t will stay cool enough. I plan to bog it and do some slow speed crawling. just wondering how often you guys have to sut down becasue its getting too hot.
Quote from: Red97 on January 18, 2012, 12:56:08 AM
I went by trial and error lol  ended up just mounting a couple of elec. fans on rad. in back and have never had a over heating issue and never have to shut down.  but as long as your moving you should be alright but going slow or crawling or trails youll probably run hot. fans are easy to install and I just wired mine to toggles and just keep an eye on temp gauge.
Boggen Joe
What kind of hose you run going front to back and where you get it?
Electrical conduit,  1 1/2''     Home Depot   just over $10 for 10'
Newbie
Quote from: xjs3667 on January 18, 2012, 03:19:19 AM
you talking about pvc? or the liquid tight flexible tubing?
I like the fact that you would be adding a couple more gallons to the system,  with that being said is there any loss in pressure in the cooling system?  Do you run a thermostat or run open flow?
Quote from: Newbie on January 18, 2012, 03:34:49 AM
metal conduit
Quote from: michigan maniac on January 18, 2012, 03:38:10 AM
no loss in pressure in system unless there is a leak,  remember the pressure is not created from the pump it is from the heat,  I run open since most my time running is in summer and Have no need for heat,  I also run a heavy duty pump, probably not necessary  but I figure I'm pushing more fluid and had it laying around.
Newbie
thanks! im gonna be using that piping! and may look into a bigger water pump sense you brought that up.
Squirell
Quote from: Newbie on January 18, 2012, 03:51:11 AM
I used a stock pump in my s10 and never had any cooling problems and I used muffler pipe
I used exhuast pipe and a stock pump for years now I got my elec. water pump.. I love how it works
bigdawg41
I used 1 1/2 and 1 3/4 inch exhaust pipe on mine also use stock water pump. use a restricter washer instead of a thermostat,always flowing. also run a Howe radiator with 1 16" fan. Up at Rocks and Valleys it runs about 170-180 degrees on a 45 minute trail.run a seperate trans cooler in front of rad. it runs less than 150 degrees on the 45 minute trail.i also installed a cover over the radiater and get very little mud in the fins.
