BLOOD THIRSTY
Started by Merc09, March 07, 2013, 12:44:19 PM
fordrunner
Merc09
I painted the headers and bolted em on. Got some starter bolts and put the starter on. I revamped the dash and made a switch box and a dash thats is a little closer for the guages. I mounted all the guages and started wiring everything up. The fuel cell is finaly secure. And i also started switching my rims around. Getting close!!! I should have it turning over in the next couple days. And running hopefully in a week or 2
Jthomas
What else do you need to make her run?
fordrunner
If I was that close u wouldn't be able to do pull me out of the shop! Hell the bronco don't have headers, valve covers, proper fuel system and i had to here it run makes me work harder knowing it will rum and that close to the finish but that's me
Merc09
I still need an alt. But i have to pull my intake off and put on lifter valley gaskets. Then i can put my dist. in and wire that up. I have to get a tac. I have to hook up the guages. Finish the wiring. Get a upper rad hose. Get oil,trans fluid, gas, and water. Hook up powersteering. And get a rear driveshaft made. Btw on my intake theres a plug right infront of the thermostat housing where i should beable to put my coolant temp switch but its corroded in to the intake. How should i get it out. It allready rounded out the 3/8 drive square in side of it. So idk what to do. Do they make a fitting i could put inline with my rad hose that the cts would screw into? I still have to yun trans lines spark plug wires. Hook up the carb. I also still need fenders and hood hinges. Theres still quite a bit to do but its all the little details lol. Oh and fordrunner i didnt leave my garage for a while. I was awake at 9:30am on tuesday and i didnt go to sleep till 2pm wednesday. Lol
Jthomas
Quote from: Merc09 on August 22, 2013, 11:12:05 AM
Text me.
Merc09
Merc09
ITS REALLY CLOSE TO RUNNING. I NEED A FLOOR SHIFTER, DIPSTICK TUBE AND DIPSTICK FOR THE TRANS, INLINE FUEL REGULATOR, FLUIDS, FINISH WIRING, A REAR D SHAFT MADE AND A SERPENTINE BELT AND SHES READY!
84silverado
Just put a rod threw the floor to shift loll works for me
Jthomas
I might have a tranny dipstick tube and dipstick.
It's for a 700r4. Not sure on the difference between the 350 tho
mud gremlin
U don't need a regulator its a 7 psi
Go big or go home
Merc09
Yeah i know i posted that before you texted me lol.
Merc09
Well i havent worked on it for a few days, but its back in my garage and im gunna start work on it again. I need to prime the oil pump "Im not sure how so if someone could help that would be very much appreciated.". I got torque converter bolts for it. And im headed to advantage driveline later this week to get my rear driveshaft made and my front driveshaft finished up. I got an upper rad hose and my tac is now mounted. Due date is sept 13 but itll be close but i still have 1 more bog after that thats near me this year and thats oct 20th. I really dont want to cut into my hunting time but what happens happens lol
Jthomas
Priming the oil system is easy. Get the tool, or an old pump shaft, and put it in a drill and spin the pump for a few mins. But make sure you got enough oil in the pan, or else it just sucks air.  Should make 60+psi oil depending on the oil pump. Mines a high volume.
Merc09
#174
Well i know i have 5+ quarts in a stock oil pan which holds about 6 so i think im good there. Would autozone rent them you think?
what stock pan did you find that holds 6 qts??? all I have found were 5 qt pans i keeping buying aftermarket 7qt pans now lol
Merc09
Quote from: betterbeaters on September 02, 2013, 03:43:17 PM
Its a 94 pan off a tbi 350 lol
Merc09
Thinking of names for this thing. I had the idea of "DIRTY INTENTIONS" but im not to sure. Maybe you guys could help.
all the tbi motors I had were 5 qt pans lucky you for finding a 6qt
Merc09
Quote from: betterbeaters on September 02, 2013, 10:43:28 PM
My 97 vortec is a 6 quart pan too. Lol
